Proper outboard HP for Irwin 28
Apr 23, 2014
54
Irwin 28 Long Island
Hey everyone, I have a dumb question. I'm having problems with my Atomic 4 and have literally been rebuilding it component by component lately. So while I do plan on having my inboard tip top, I thought an outboard, especially as a backup for long cruises, would be a good idea. So I'm going to mount a kicker bracket, and pick up a used long shaft outboard.
My Irwin 28 has a 7800 pound total displacement. So I know I should probably get a 10 horse outboard.
Question is, I found an affordable 8HP Mercury. Would this be powerful enough for my sailboat?
Any and all advice, comments, thoughts are appreciated.
jimg
Jun 5, 2004
175
catalina 27 dana point
Yes. Although a larger would be better, this will work fine. I normally use a 15hp on my C27 of about the same weight, but I have used a 6hp which pushed it at 6 knots easily.
Pearson 26W Marblehead
outboard for 7800 displacement boat
6hp will do the job under most conditions 10 hp will give you more reserve power against a still breeze on the nose or a heavy chop.
May 24, 2004
7,213
CC 30 South Florida
Currents can be real strong in the Long Island Sound. I would advice you look for at least a 15HP outboard.
Catalina 310 278 Lyndeborough NH
The 8 HP engine is probably the same engine as the 10 HP (excuse me - 9.9) but has a derated fuel delivery system.
As a back-up motor, it should be sufficient. If you later find a good deal on a 15 HP outboard, this one could be used for something else.
Nov 9, 2012
2,500
Oday 192 Lake Nockamixon
Whatever you get, even a smaller motor, make sure you get (or it already has) a high thrust propellor.
These are usually 3 or 4 round "Mickey Mouse ears" blades, total prop diameter that just fits under the anti-ventilation plate, and has a low pitch measurement.
A high thrust prop will manage any sailboat better than the stock prop, which is usually designed for running jon boats at speed.
