proper etiquite for flag flying
Dec 25, 2014
84
Catalina 27 Pasadena, Md
I finally got the flag halyard strung on my starboard spreader, but want to follow proper etiquite. What is the proper etiquite for flag flying when you live and reside in the US but are also proudly of Canadian heritage? I have dual US and Canadial citizenship, and I googled and am reasonably certain the US flag is flown on the aft flagstaff, but wondered about the correct way of displaying the Yacht Ensign and the Canadian flag on the starboard flag halyard.
Also what about any "novelty" type flags as well?
As a proud citizen of both countries, I wish to fly correctly the flags that represents my heritage and my current residence in the US (Chesapeake bay area) in a manner that is courteous and respectful to all. Any recomendations would be entertained and processed.
Thanks
A Canuk who is also currently an Yankee.
Nov 8, 2010
11,386
Proper?
Heritage does not factor. American boat in American waters? Fly only the American flag. That's proper.
Jul 27, 2011
5,203
Bavaria 38E Alamitos Bay
If a US-registered vessel, one flies the US National flag or the Yacht Ensign from the flag staff mounted on the center line, or on the starboard side, of the transom; this is true regardless of whose national waters you might be travelling through. If you take the boat to Canada, fly the Mapleleaf on the starboard spreader; if to the Bahamas, then the Bahamian national flag there on the starboard spreader, etc. You could fly the Maryland state flag there as well while in Maryland waters, but switch to Virginia when in those waters, etc. BUT you would not fly the Canadian national flag from the starboard spreader while traveling in US waters. Novelty flags are flown from the port-side spreader--since you asked. When I cruise Canadian waters in a US-registered boat, the Mapleleaf goes on the starboard spreader with the Province flag, typically British Columbia, below it. If you wish to show your heritage, buy a pin for the hat. For example, if a Newfoundlander, then...
OR below for dual citizenship.
Joe
Jun 1, 2004
8,345
If your boat is registered in US then you would fly the US national ensign at the stern or mainsail leech. Besides paying respect to foreign countries you may visit in your vessel, the courtesy flag position on the starboard spreader can display the national flags of your guests... and yourself. So... Full size US flag (1" per one foot boat length) at the stern to represent the ship, half size Canadian flag on stb spreader to honor your dual citizenship.
The following piece, excerpted from a flag etiquette article, will give you more detail:
Courtesy Flags:
As a matter of courtesy, it is appropriate to fly the flag of a foreign nation on your boat when you enter and operate on its waters. There are only a limited number of positions from which flags may be displayed. Therefore, when a flag of another nation is flown, it usually must displace one of the flags displayed in home waters. However, it is hoisted only after the appropriate authorities have granted clearance. Until clearance is obtained, a boat must fly the yellow'Q' flag. Often cruising sailors fly both the courtesy flag and the quarantine flag (Q flag below) on entering a foreign port.
The courtesy flag is flown at the boat's starboard spreader, whether the ensign is at the stern staff, or flown from the leech. If there is more than one mast, the courtesy flag is flown from the starboard spreader of the forward mast.
It is considered disrespectful and rude to fly a courtesy flag that is old, tattered or raggy. Make sure that you replace flags that do not do justice to the country you are visiting
Lastly, it is also a common courtesy to fly the national flag(s) of your guest(s) on board, if they have a different nationality than the ensign is showing.
Courtesy flags are normally the maritime flag of the country which in most cases will be that same as the National Flag (e.g. France, USA, Netherlands) others may be the National Flag defaced with a device (e.g. Italy, Finland, Morocco) and others may be a totally different flag (e.g. UK, Australia, New Zealand). If you are planning to visit
a foreign country, find out the correct maritime flag from some of the sources shown at the end of this article. Most quality specialist flag shops will have the information.
Flags' Dimensions:
Flags come in standardized sizes, but there are guidelines about selecting the proper size for your boat.
The size of a nautical flag is determined by the size of the boat that flies it. Flags are more often too small than too large. So in the rules below, round upward to the nearest larger standard size.
The flag at the stern of your boat: The ensign or national flag should be about one inch for each foot of overall length. For example, on a 40ft. boat, the ensign should be 40 in. i.e. about 3.5ft.
Other flags, such as club burgees, private signals and courtesy flags used on sailboats should be approximately 1/2 inch for each foot of the highest mast above the water. For example, on a 30ft. boat, with 50ft. between the masthead and the water, the burgee should be about 25 in. The shape and proportions of pennants and burgees will be prescribed by the organization which they relate to.
Kermit
Jul 31, 2010
5,722
Good luck figuring out the actual proper, right, correct, last-word answer. I've improved my etiquette but doubt I'm perfectly in compliance. Especially in South Carolina since I don't fly the Confederate Battle Flag.
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
although not correct at this point i fly the (SBO) only flag/burgee on the starboard spreader halyard..... in time i may rig up a pig stick and fly it up there
Dec 29, 2014
14
Hunter 33 Dallas
In the US you fly US flag aft and the TEXAS flag under it.
the US flag is always the largest Flag.. and at the highest point. any other state or country flag must be smaller and below it.. war ships will have a union jack on the bow.
Jul 27, 2011
5,203
No other flag may be flown directly over the US flag; this is does not mean it must be at the highest point on the rig. Clearly, it would not be if flow from a flagstaff aft while a yacht club burgee, or other pennant, is flown from the mast head or spreader, which is proper etiquette.
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
there is a lot of good info in the chapman's piloting and seamanship book....which by the way should be on board every boat
Nov 8, 2010
11,386
All of the first three answers said the exact same thing! Just with a different number of words. I like economy. ;^)
Kermit
Jul 31, 2010
5,722
+1.
Everything else is just us speculating. I always thought flying all flags on the starboard spreader with the US flag on top was correct. Just like a flagpole. I still think it looks the best but it's clearly wrong. My way now is the US flag on the stern rail and all others from the starboard spreader. The SC flag goes on top, then any other state flag of guests who may be with us. Then our club burgee below. That's still not correct but no one on Lake Murray has fussed at me. If they do I'll have to put up the Gonzalez flag.
Likes: Justin_NSA
Jul 7, 2004
8,542
Hunter 30T Cheney, KS
+1.
