Good Question!
Just replaced the prop on my 26X and it made a tremendous difference. I went from the stock 13 pitch to an 8 pitch, 12" prop. This was on a Honda 50 and your diameter needs might be different. Before, the engine would barely get 3k rpm. Now it will redline if I want it to, and planes the 26X easily. Totally different experience. The weight of the X seems to need this pitch to get the power needed. Otherwise, you just sit there with the engine pushing as hard as it can and the bow way up in the air.
