Bob Moretti
Last week, while singlehanding my Catalina 30 one night, the propeller fell off and was lost to the depths. How this happened will never be known for certain. It was an expensive feathering propeller that had been on the boat for 6 years. The tow back into my tight slip was also $$$$.Anyway, I hired a diver to put my original fixed-blade prop back on the boat. He discovered that the prop shaft had been cut down a bit as part of the installation for the feathering prop which I had lost. As a consequence, there were not enough threads on the shaft to install both the usual jam nut and locking nut. He could only fit the one, full-height nut, which he tells me he fully engaged on the shaft, torquing it down hard. No cotter pin could be placed, since that part of the shaft was gone.I have to make a 12 mile trip to get hauled out for the season, which is now over here in Chicago. While I can sail most of the way, the last mile and a half will be up a river that has very large barge traffic. Naturally, I'm concerned that my propeller stay attached! But I'm wondering if any of you have had your propeller similarly installed for some brief period of time, hopefully without problem. If so, should I motor at very low RPM's? Lock the shaft in gear while sailing? Any thoughts are appreciated.
