Propeller Blades
Nov 8, 2003
166
I will be repowering with a beta and putting a new shaft and prop. How
long is the new shaft supposed to be and should I go with a 2 or 3
blade prop?
Nov 8, 2001
1,818
Hi
I supply a 1.1 or 1.2 mtere shaft which is too long. This is cut to
length depending on whether you have rope-cutter, shaft anode etc
fitted.
Cheers
Steve B
Nov 8, 2003
166
Hi Steve,
Do you use a 2 blade or three blade prop on your boat? What are the
advantages and disadvantages of each?
Robert
Nov 8, 2001
1,818
Hi Robert
I use a 3 blade prop so I have better control in reverse and more
instant power. Doesnt seem to make a lot of difference under sail,
especially as teh wind gets stronger.
Cheers
Steve B
Aug 1, 2000
95
I repowered several years ago with the Beta from Steve...went with the shaft and 3 bladed prop that Steve supplied. Nothing to do but install same, shaft was exactly the right length and diameter. 3 bladed prop gives me considerably more control when backing,...a big difference in control.
Hans Heiduck
V-1874, "Flicka"
Oct 31, 2019
6
I had the same experience as Hans. Couldn't believe how simple it was to repower.
After 4 seasons with new Beta 13.5hp all I can say is 'Super'
David Daly
Vega 1781 'Curlew'
Hans Heiduck
V-1874, "Flicka"
May 30, 2006
1,075
Has anyone heard of or used a Kiwiprop?
It is featured in Practical Sailor in the latest issue.
Kiwiprops.com I think.
Plastic blades. Less weight outwards yields less vibration and noise and wear on bearings.
Blades mounted on some type of metal turning axles, so it is feathering somehow. I don't fully understand it's operation.
roy
Oct 31, 2019
562
hmmm.. I hit the wrong button...
I'd stay away from plastic folding props- unless you're
planning to participate in races.
The shaft for a Vega is quite short, about one meter, and
quite thick (25mm)for its length , and properly adjusted,
there shouldn't be any vibration.
Wilhelm, V-257
Oct 30, 2019
1,459
I have a 3 bladed Maxprop that works great astern and ahead, and feathers when sailing. Been trouble free for 7 years. I love it. Came with the boatNicholas Walsh
Nicholas H. Walsh P.A.
111 Commercial Street
Portland Maine 04101
Tel. 207/772-2191
fax 207/774-3940
This email was sent from the law firm of Nicholas H. Walsh P.A. It may contain information that is privileged and confidential. If you suspect that you were not intended to receive this email, please delete it and notify us as soon as possible. Thank you.
Oct 31, 2019
562
Hi Nico;
I guess you don't have problems with those pesky barnacles.
I'm sailing in tropical waters where the water is around 80
F (27 C) and I have to clean the prop every 3 months, more
often in Summer.Folding props don't work too good here.
Wilhelm, V-258
Nov 8, 2003
166
Hi everyone,
It looks like most of you have gone to a 3 blade prop with good
results and no complaints under sail and a shaft of 3 1/2 to 4 ft.
depending on zincs and rope cutter appears about norm.
Thank you all for your help.
Robert
Oct 31, 2019
303
In the thread on Propellers, rope cutters were sometimes mentioned. I have
never used one on any of the boats I've owned, but could have used one a
couple times. Since I am now refitting the entire power train on Flyaway
(Vega 2023), I might add one.
What type of rope cutters are folks using and how well do they work. Any
comments on installation would also be appreciated. Probably a more
important question is: what rope cutters to stay away from.
Thanks,
Chris
Nov 8, 2001
1,818
Hi Chris
Dont buy teh cheap disk cutters, they are useless.
The one I like is called The Stripper made by Ambassador Marine in the
UK. They are not cheap (about £250) but they certainly work beautifully.
If you need one then let me know as I have contact with teh owner of
Ambassador marine.
Cheers
Steve B
