Actually I believe it is against USCG regulations to mount a tank in a
position where the propane could enter through a vent or any opening into
the boat. All propane installations have to have a clear, unobstructed
drain, down and overboard. Also there has to be a shutoff at the tanks (most
new boats use an electric solenoid here). US law then requires a single hose
with no connections from the shutoff valve at the tank to the appliance
valve (at least this was the law last time I did an installation, a few
years ago). I once had my big boat surveyed by a European surveyor before a
crossing and he said the European law was different regarding the hose
connecting the tank to the appliance (though I don't remember the
particulars).
I once saw a very interesting article of an installation of propane tanks on
deck. They used a very large, white plastic drain pipe. This was clamped to
the pulpit or maybe the rig. They had a plywood top and bottom fitted (and
painted to match). Of course they had the proper drains for the propane and
the connection hose. The solenoid valve was fitted inside the housing.
One thought about mounting it on the rear deck. Maybe it would work to use a
tank housing as above, with a drain hose going into the deck and exiting the
transom, below the deck - or something like that. I haven't thought it
through thoroughly - comments or suggestions welcome as I am planning just
such an installation this spring.
_____
AlbinVega@yahoogroups.com [mailto:
AlbinVega@yahoogroups.com] On Behalf
Of alan_critchlow
Sent: Saturday, February 04, 2006 8:49 AM
To:
Subject: [AlbinVega] Re: Propane Stoves
Hello Melanie & Paul Halvachs, I thought of intalling them there as
well but I am worried about the engine vent on deck. I no longer use
it so I suppose I could block it off. I would not want any leaking
gas go through the vent to exactly where I do not want.
Alan & Felicity
