Propane storage replacement
Dec 25, 2018
34
ODay 34 262 Galesville MD
My 1984 34 footer has vented lockers for 2 liquid propane tanks. the plastic liners in the lockers are original and getting brittle. Has anyone found a good replacement for the liners?
dmax
Jul 29, 2018
1,268
Telstar 28 Buzzards Bay
I'm assuming the vented lockers are the same on the 34 as the 35: on mine, the plastic liners in the lazarettes are specific to the boat and no longer available. Maybe you could find some from a parted out 34-35, otherwise it's repair them or build custom.
Jan 27, 2008
3,092
ODay 35 Beaufort, NC
Perhaps you could slather them with release agent then lay up new fiberglass ones using those as the mold. The fiberglass ones will be a little larger so it may be an issue with the fit. You could then use the one you laid up as the "mold" and lay up on the inside of the new one to get an exact size replacement. Personally my solenoid valve corroded and it was time for new hoses, and regulator, etc. So I scrapped the whole mess and the stove and installed an origo stove/oven to run off alcohol. Very happy with the replacement.
