Just wondering what the protocol is here: On my new MH 40, the propane tank is located inside a second compartment that is inside a lazarette compartment. It is not easy to access once the tank is installed.
The question is: Should I turn the propane on and off at the tank each time I use it? I used to do this on my H36, but all I had to do was open a hatch and turn the valve. I would have to empty out anything stored in the compartment, then open the second door to reach inside the special propane locker. Seems like they mounted the propane tank out of the way on purpose.
