Propane Pigtail -- Loose the wrench
roriol
Mar 7, 2012
3
Hunter 466 Barrington, RI
Hi,
After spending an hour searching the boat for the propane wrench for the old POL style propane bottle connection, I decided to investigate if it was possible to upgrade the pigtail--the hose that goes from the regulator to the propane 10lb propane tank. It certainly was. I ordered a new style 15" propane pigtail (Cavagna (50-A-190-0033) 15" Acme LP Pigtail-NPT) from amazon, about $13. And with a little bit of Megaloc thread sealing paste I was able to do a quick upgrade. Just make sure when removing the old POL style pigtail that you steady the joint with a pair of pliers.
