propane levels
May 24, 2004
7,164
CC 30 South Florida
Yes it will work but I prefer weighing the tank. Before filling you weigh the empty tank; a 20 lb capacity propane tank is around 18 lbs give or take 8 oz. There should be a stamp in the bottom with the actual weigh of that particular tank (ex. TW18.2). One gallon of propane weighs 4.2 lbs and a 20lb tank usually holds 4.7 gallons or 19.74 lbs. So a full tank should weigh 18+19.74= 37.74 lbs. If at any time you want to know how much propane you have left just weigh the tank and substract the weight of the empty tank. It is easy to estimate 1/4(23lbs), 1/2(28lbs) ,3/4(33lbs) and full (38lbs). Smaller and lighter tanks will weigh less and will hold a lesser volume but the principles are the same. I have not found any accurate gauges as the tank will hold a constant pressure up until the point it is empty.
Benny, serious question: how do you weight it on the boat? Do you have a scale? I usually leave our bathroom scale at home when I go cruising.:)
Mar 20, 2012
3,983
its not really so important to know how much propane you have left in the tank, as it is to know whether the spare is full or empty...
I have never worried or cared how much is left, although I have sometimes wondered where it went so quickly... I just connect the spare, check for leaks, and try to remember to refill the spare..:D.
Mar 20, 2012
3,983
dang!... all these calculations for different tank sizes and composition (steel vs aluminum vs fiberglass) when you could have just poured hot water over it?;)
and the gauges can be highly accurate, but due to the properties of the propane, it wont allow itself to be measured by a pressure gauge, without an unecessary amount of much more complicated calculations and equasions....
Johnb
Hunter 37-cutter Richmond CA
A $10 luggage scale. Since it goes up to 100 pounds we can also for the trout we catch.:D
Oct 2, 2008
3,810
Pearson/ 530 Strafford, NH
Here's a rough scale. Block at the end of the boom, line tied to tank, through the block and tied to a twenty pound anchor held one foot off the deck. Anchor touches the deck, time for a refill. Works if the empty tank is slightly less than twenty pounds.
All U Get
May 24, 2004
7,164
CC 30 South Florida
Well, you got me, I was just illustrating a more accurate method. In the boat I now use the pick up and shake method and let my time developed sense of the slosh I feel inside the tank indicate a good enough approximation of the fuel available. Like centerline says there is no need to worry too much as long as you know the spare tank is full. I still use the weight method on the tanks for the RV before going on a trip. :redface:
Sep 28, 2008
922
Canadian Sailcraft CS27 Victoria B.C.
If you fish you probably have a small scale for weighing them.
Jul 27, 2011
5,134
Bavaria 38E Alamitos Bay
If I have to remove the tank from its fitting and locker to do a test, I'd just as soon get the thing filled if I'm ashore. That is, if you think you're soon to run out-fill it; if you do run out, then you don't need the test.
Apex
Jun 19, 2013
1,212
C&C 30 Elk Rapids
Two different options for the same: google digital propane scale. TVL is a LCD display and the scale stays under the tank, or for those app savvy, there is a quirky brand that displays to your phone.
http://www.brookstone.com/refuel-smart-propane-tank-gauge-for-smartphones?bkeid=compare%7cmercent%7cgooglebaseads%7csearch&mr:trackingCode=C14E4BDB-1350-E411-ABF1-001B21A69EB0&mr:referralID=NA&mr:device=c&mr:adType=plaonline&mr:ad=64643122884&mr:keyword=&mr:match=&mr:filter=50622810175&gclid=CODEi9D37cMCFQaLaQodfZsA6g
Saw the smart phone model on ask this old house! Love that show
and here is the tvlhttp://www.grabcart.com/product/day5155-rtl58913?gclid=CKKX8vj57cMCFYc8aQodQVoAVw
