Propane hose leak
Gunni
Mar 16, 2010
5,937
A leak test indicates that the propane hose (tank POL fitting to the gas regulator) is leaking at the swivel fitting threaded to the regulator. I attempted to wrench it free, but not coming loose. Note that BUSA sells the entire hose/regulator/solenoid assembly for $170. All I need is that hose. Anyone had any luck separating the parts and just replacing the propane hose?
