Prop
maisso
Aug 2, 2012
4
S2 9.2A Ashland
I have a 1983 9.2A.
Current Configuration:
Yanmar 2GM
2 blade fixtes prop (Dia & pitch unknown) I'm assuming it was stock.
I'm looking to get a little more bite from my prop - especially in reverse.
What are the trade-offs.?
Is a 3 blade the way to go.... or change of pitch in a 2 blade?
Any advice would be appreciated.
Thanks
BobM
Jun 10, 2004
3,269
S2 9.2A Winthrop, MA
You really can't change the pitch to suit reverse. The prop is picked to apply the best torque at a given rpm range. Too much load or too little is a problem. You likely just have to learn to deal with what you have. Sailboats just aren't designed to back up.
Hunter 37 C sloop Punta Gorda FL
Feathering props flip the leading edge over in reverse for more thrust.
They are available in both 2 and 3 blade I believe.
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
i have a 15d...10p 2 blade on mine it was calculated to be a 15d..11p 2 blade but i think with the age of the engine a 10p will be just right ...i do have a 11p and a 9 p just in case i am wrong....
regards
woody
