prop wallke
1
catalina 44.5 melbourne
hi all,
i have a new Catalina 44.5 and i have some difficulty when mooring the boat in reverse.
i find i have a lot of prop wallk to port when throttle at 1500 plus. i have the original factory supplied prop. can this be fixed? or do i need a different prop. perhaps a folding or a high performance prop?
George.
May 1, 2011
5,045
Pearson 37 Lusby MD
Prop walk can be your friend. You need to apply enough gitty-up to get water flowing past the rudder, then take it out of gear and put it back in gear to keep the boat in motion. Mooring the boat - bow-in or bow-out - should be a very dull, non-exciting evolution. Keep it slow!
Other Catalina 30 Tucson, AZ
Prop walk is your friend and something every skipper has to deal with.
First, I assume you have clockwise right rotation. Second, increasing acceleration will just make things worse so go easy on the accelerator.Third, what I'm about to tell you is hard to visualize sitting at a computer and if you decide to practice do it in a turning basin until you get the hang of it.
BACKING THE BOAT: At my dock I need to back out and have the stern turn to starboard so I can exit the slipway into the turning basin. Here's how I do it. The first part is obvious but the second part isn't. I obviously start with the rudder centered and the engine in slow reverse. Once 3/4 of the boat is in the slipway I use prop walk to my advantage. I put the engine in FORWARD. Sounds wierd but the stern swings slowly to starboard.
Say something is happening in the slipway and I don't have time to fool around. To whip the stern around I'd still stay in FORWARD but I'd turn the rudder to port and goose it. The stern will rapidly turn to starboard.
PORT SIDE DOCKING: Approach the dock at slow speed with the bow slightly angled toward the dock. Center the rudder and put the engine in REVERSE. The stern will swing nicely and easily toward the dock. Here's where skippers get into trouble in this situation. Instead of CENTERING the rudder they turn to port with the engin in reverse. Nothing happens at first so they goose the engine. As soon as they do that the stern turns to starboard. To correct the situation they turn the rudder to starboard and that's when things get really screw up. What they should have done with the centered rudder is NOTHING.
On Catalina Island it is sometimes fun to watch how skippers get into trouble with prop walk. One place is the fuel dock and the other is picking up a mooring. The skipper approaches the mooring a bit too fast. His rudder is centered, which is good, but then he floors it to stop his forward progress. I say to myself, "DON"T TOUCH THE RUDDER" but they always do and that when things go from bad to worse. The skipper then over corrects and it end up being a Chinese fire dril except the Chinese fire drill is better organized!!
Practice in your turning basin to see how the forward and backward motion of your boat is influenced by the position of your rudder.Also see what happens when you goose the engine. If your rudder is not in the correct position things go badly rapidly.
hewebb
Oct 8, 2011
329
Catalina Catalina 25 Joe Pool Lake
I had been told that a three bladed prop will eliminate this, but I have not been able to verify that. I have learned to use that to my advantage. Backing out of my slip I let the boat turn with the prop walk then when out of the slip facing the opposite direction put it in forward to complete the turn and exit the slip area. That is a 180 deg turn coming out then a 90 deg turn to head out. Luckily I have a wide enough area to make that move with a couple of feet to spare. Returning to the slip very slowly when time I reverse let the boat walk to the port side to grab the aft port dock line then in forward swing boat to starboard and get the starboard aft dock line. If I have someone with me I ask them to grab a forward line on the upwind side while I get the aft line.
Catalina 320 Dana Point
My personal experience has been just the opposite, seems like the third blade just gets you 1/3 more propwalk.
