I have had conflicting reports concerning a hard pull to port when the boat is under power, which is my condition. The prop that came with the boat is a 18x12 3 blade fixed prop. The wind or waves do not affect the condition. If you release the wheel when the engine is at least 2500RPM or more the boat will make a hard emergency turn to port and the wheel will spin like a top. I was wondering if anyone else has had this experience and what if anything was done to solve it or lessen the pull. The boat also reacts very slowly to a reverse input. It takes quite a while when going at 1 knt or less for the boat to respond to reverse. I have also heard that this is not a problem in other models.Any input would be appreciated.
