My '77 C-30 Doesn't
Hey Guys,I just want to be sure we're talking about the same thing, here. "Prop walk" is when the boat travels sideways as a result of the propeller's movement when the boat has no headway. The ONLY time this happens is when the boat has 0 speed over water and the engine is in gear. This is common when starting from a dead stop or when shifting from forward to reverse.Once the boat gains some speed the rudder & keel will more than compensate for any prop walk and you should be able to achieve a straight course.When you guys say the boat "steers to port" do mean that your boat can't go straight, or do you mean that you constantly have to have your hands on the wheel to keep it from veering to port? Under no circumstances should the boat go sideways while moving through the water 1 knot or more. It's impossible, as long as the keel & rudder are still attached to the boat. If you're bothered by it veering to port without a steady hand on the helm, then that is not prop walk. It is a pain in the neck, though. I've been at cruising rpm's on a long windless leg, taken my hand off the wheel to grab a water and within 4 seconds we're hard over to port. Oh well.To answer the question...I don't think there's anything you can do about it except maybe get a wheel lock for your steering pedestal and keep it relatively tight when on a long straight course. That helps a little when it's being steered by hand, but it's no help when you have the autopilot running.As for when the autopilot is getting over worked, you definitely have something wrong with the autopilot. It may be too small for your boat, it may be a slipping belt, a worn (weak) motor or bad wiring to the motor or the settings might be off (though I doubt it if the autopilot works well while under sail). How old is it? What brand?? Maybe we can help.Good luck,Allen Schweitzers/v FalstaffC-30 Hull# 632
