It isjust part of the program
Luke: Once you get your boat moving it will back down straight as an arrow. the trick, as mentioned by Gene, is to get it moving. Start moving in reverse by aiming the transom slightly to starboard of where you actually want to go. Give the engine some throttle and as the boat begins to move back and to port back off the gas. The boat will then begin to behave as you want it to. I sometimes find my self in a position where I need to back down a long way. So I stand forward of the wheel, facing aft, and just begin to drive the boat as if nothing was different. It works amazingly well. Practice a few times in open water 'till you master the technique. As Gene said, "use the force".pjwalch
