I'm not sure I understand. You are going forward and you put the boat in reverse and it makes a 180? (Assuming this is in flat seas, no wind, little or not current?)
The trick to using prop walk to your advantage is the throttle. You really have to goose it to make the boat begin to start working/moving in reverse under control of the helm, because unless you do there will be little or no water movement over the rudder, and the prop walk will continue. Most folks who complain about prop walk, as compared to learning how to use it, do not move the throttle above idle, hence, the continuing move to port without going into reverse.
Good luck. Look at it this way: since you have to practice to learn how to use it, you get to use your boat more often.
Find an open stretch of water and spend a half hour working on it, it will happen. Take the boat out of gear while moving forward and wait til it almost stops. Engage reverse at idle and your stern will move to port. Increase the throttle until you can use the rudder to seer, then back off the throttle. You should be able to go straight in reverse, using the throttle, for miles... It's like docking, do it a few times instead of just at the end of the day, and you'll be a better more relaxed skipper.
Have fun.
