Is the effect of prop walk different on an outboard motor than an inboard motor. Given a right hand prop, prop walk will cause the stern to move to the port when backing. But the difference is in an inboard, clean water is passing over the rudder while on an outboard, the prop wash is deflected off the rudder when in reverse.Any helpfull hints on backing out of a tight spot? Wind is from astern, channel is to port with wind hitting my port side as I back out to starboard.Thanks.
