That's Fun, Don and Fred ;D
Didn't think you both could be right, but here is a quote from the installation manual (of the newer one which has the in-the-water adjustment feature): "4) PROPELLER USE The Max Prop works automatically. By putting the engine in gear the blades will engage in either forward or reverse. The best way to feather the propeller is; Power at 2 to 3 knots in forward. Kill the engine while still engaged in forward. When the engine has stopped, if the shaft is still spinning engage the transmission in reverse to stop the freewheeling. You can check to see if the propeller is feathered or not by taking the engine out of gear. If the propeller is not feathered the shaft will freewheel like with a fixed blade propeller.In that case start the engine again and repeat the three steps. If your propeller has been greased properly it will feather in a fraction of a second as soon as you stop the shaft from freewheeling. Once the prop is feathered, you can either leave the transmission in gear or out of gear, it does not matter. DO NOT kill the engine while in reverse. In this case the blades will be in the reverse position and will not feather. You can actually use this feature to drive a shaft alternator.IMPORTANT: If the Max-Prop is installed on a vessel that can attain sailing speeds over 15 knots, it is MANDATORY to return the transmission to neutral while sailing. If the transmission remains engaged and the propeller were to open (from hitting an object or water flow) it may turn the engine, flooding it, resulting damage to the engine."
