Tim, It looks like responses are absent So I'l ask you a question
Not having a Citation I'm not familiar with the prop clearance. You may not know that you need a couple of inches clearance between the tip of the blade and the hull to prevent cavitation. Cavitation would produce a disintegration of the edge of the prop similar to electrolysis. So if you measured the perpendicular distance from your center line of your shaft to the hull, and subtracted approximately 2 inches you would have the max radius of the prop. Double that for your diameter and thats your starting point. So the question is: what is your max allowable diameter?Your pitch will vary with the diameter. The smaller the diameter the larger the pitch. It's generally better to swing the largest diameter and the lowest pitch as the prop bites quicker and has less side thrust. More important when you mare backing.I'l try to come up with something a little more definitive for you but it may take me a little while. I have a friend who has a Ranger 37 with the same engine and a 2 bladed Max Prop. I'l try to find out what prop he swings.Any one else with any Info should feel free to jump in here.Joe S
