1) On my 2005 310 the diagram (see attachment) in the manual for the stuffing box shows the packing as 3/16" and three rings yet when I removed the old one it looks like ¼" does anyone have an updated drawing?
2) Check the next two pictures (shaft going through the hull) in the manual they direct you to perform the prop shaft line up/couplings to be performed in the water to allow of flex in the hull, and I have checked this a couple of times and appears to be good. However in the drawing that shows the stuffing box details it recommends the shaft be centered in the fiberglass tube. In the attached pictures you can see that the shaft appears to be closer to the bottom of the opening then the top although it is not touching as best I can tell. Which is correct? And do I need to remove that reinforced rubber hose that connects the stuffing box to the fiberglass tube to see if the shaft is centered? The reason for my asking,, ever since I purchased the boat in 2010 when the boat is sitting at the dock idling in neutral there is especially on the port side a sharp tapping noise, that to me does not sounds right. I have checked and double checked the idle which is set to 1100 rpm as I know this can be somewhat related. My concern is that some where there is a hole being knocked in the hull and I am trying to prevent this. Any ideas welcome
BR Paul
BR Paul
