Prop shaft strut bearing
SK
We have a 1973 "27" the prop shaft strut bearing is worn pretty good is it a hard job repairing or replacing. Just got the boat and It's my first sailboat.Thanks
Robert Fischer
simple but difficult job
The job is fairly simple, but the removal of the old bearing can be very difficult. Your model may have a set screw on the side of the strut,clean off the strut thoroughly before starting. Use a wheel puller to remove the old bearing. You should be able to get info on this process from your local library Good luck.
O
Omar Van Rooyen
Simple, but it can be done
This is the Cutless bearing. There is a good article about the procedure in this month's Cruising World. On my boat, it was necessary to pull the shaft in order to get the bearing out. That required dropping the rudder. So the procedurre was more complicated for me.
Melody Miller
Not an Easy Task for My Boat
Hi SK My cutlass bearing was replaced about 3 weeks ago (76 Catalina 27). It was not easy. The engine had to be moved (Atomic 4). The mechanic that did the work is an excellant mechanic, so it wasn't lack of experience that led him to move the engine. I have not talked to Larry about all the particulars, but I think it was related to a "clearance" problem between the shaft and hull and the availability of a small enough tool to work in the space. The bill has not arrived for this work and I am in no hurry to receive it! Melody Miller
