We have a Morgan 32 with an Universal M25 diesel engine. In the warm months (May - September), the engine will start to make a sqealing sound that gets louder and louder until the prop shaft stops rotating and the engine dies. It sounds like the prop shaft is slowly getting hotter and hotter until it can't move at all. After the engine stalls, we check the temperature of the shaft and it is not even hot. We have been unable to figure out the cause of this problem. The cutlass bearing was replaced but the old one was not worn. We have adjusted the engine mounts multiple times, but that has not fixed the problem. We have also replaced the water pump impeller. It only happens in the summer months and runs perfectly all fall and winter. Could this be a problem of overheating? Our temperature guage doesn't work so we don't really know if it is overheating. It seems to happen more often if there is trash in the water. Could the engine be clogged? Any suggestions would be greatly appreciated. We don't have a yard or a good mechanic in our area and have been trying to figure this problem out for two years. Thanks!
