Prop Shaft Removal
Oday 35 Toronto, Ontario
I need to replace the cutlass bearing on my ODAY 35 and will need to remove the prop shaft. Does anyone know if it will come out without removing the rudder?
RAD
Jun 3, 2004
2,330
Catalina 30 Bay Shore, N.Y.
Ask the yard to do the cutlass bearing cause then they will use the special tools to remove the bearing without removing the shaft.
I have a 32 and I have to remove my rudder to remove the shaft and this fall I asked the yard if the shaft needs to be removed for the cutlass and they said no
