OK, this is driving me nuts. My 85 H31 has developed a strange knocking (thumping?, slapping?) sound that I think is related to the prop shaft.
It doesn't happen all the time, and seems to be related to how heavy a load is on the engine (2GM20F). It happens in forward and reverse, usually when I rev up quickly (like when pulling into the slip and using reverse to stop, or after pulling out of the slip and switching to forward motion). It also happens when I'm motoring if I increase RPMs too quickly. I can get it to stop by backing down and then gradually increasing RPMs (I usually motor around 2600-2800 RPM).
I've looked at the shaft going into the stuffing box, and can't detect anything out of line, even when the shaft is turning. I've had my diver check the cutlass bearing, and that seems OK.
The frequency is the knocking is less than the shaft RPM. For example, if the shaft were turning at 60 RPM, the knocking might be 10 times a minute.
I'm completely baffled and I'm hoping the collective wisdom of the Hunter Owners can help me out. Cuz whatever it is, it can't be good!
Thanks,
- Richard
S/V Discovery
San Francisco
Thanks,
- Richard
S/V Discovery
San Francisco
