prop shaft in Cutlass bearing.
Sep 21, 2025
2
hunter 27’ Cherubini urbby
Recently had her quick hauled and prop shaft wasn’t inline with Cutlass bearing. It was raised on one side lowered too low on the prop side. I’d been losing power underway. Prop doesn’t spin by hand in neutral. It’s got something Binding. Anyways been here at Stingray Point for two weeks while supposedly Factory certified marine mechanics have played whack a mole. He inspected and reclamped fuel lines and bled her off and adjust a couple screws and now it won’t it even get 1500 in neutral. How do you tune this engine? Gracias
Bobby
Jan 7, 2011
5,792
Oday 322 East Chicago, IN
You seem to be talking about 2 different issues…
Mechanical binding of the shaft (maybe at Cutlass bearing) and an engine that isn’t running right. Maybe they are related….naybe not.
First 2 questions I have:
1) is the shaft still bound up? Did anyone try to realign the engine/ shaft/ cutlass?
2) what engine do you have?
Greg
Jan 4, 2006
7,365
Hi @rssmith1965 , seems like you've got more than one issue going on here which is causing your loss of power :
I'm assuming you're on the hard when doing this and the engine is a Yanmar. You're prop is not going to spin in neutral because of the friction of the packing gland (as opposed to a mechanical seal) as well as the friction of the cutlass bearing, even if perfectly aligned. And for sure, it'll be bugger to move if the shaft coupling is still attached.
That's how mine behaves on dry land but you really get to see how it cranks over under sail and the xmission is in neutral.
Sorry, limited experience in tuning a diesel engine. Trouble shooting yes, but thankfully, no tuning.
- any chance your throttle (governor adjust) is not stroking 100% ?
- any chance your mixing elbow is plugged ?
- have you gapped the valves recently ?
So many things I'd be checking well before getting into the actual "tuning" of the engine.
