Recent issue with a dock line and my prop shaft. After getting back to the slip (towed) and having the line cut loose, and hearing a “thumping sound”, had the boat pulled out and the prop, shaft, cut-less, couplings and engine mounts checked. Found that the tube for the shaft was touching the prop shaft. So as a precaution to all of the above the motor mounts have been replaced and the engine / shaft aligned and sighted ((mechanically). I ran the engine prior to connecting the shaft to the transmission and the engine was pretty smooth, when attaching shaft and aligning all was good and the ran the engine again. Did not put into gear. I listened and watched. Ever so slightly I could a thumping at the stern.
Now I ask is it possible to raise the motor/trans to “lift the shaft” off of the tube, without putting the mounts to high? Don’t want the motor way up on the mounts.
yThe engine is a Yanmar 2GM20F, with 1104 hours on it. Cut-less bearing was deemed ok as well as shaft.
Any thoughts or help very much appreciated, in advance thanks.
