I pulled out my 1976 cat 27 a few days back and I noticed after running the engine all summer that the bracket that holds the prop shaft just before the prop has cracked the gelcoat or maybe even the fiberglass where it attaches to the body. I have sanded down about 1/8 - 1/4 inch and the crack seems to continue. I am not sure how far to dig... The hairlince crack in the hull is like a rectangle all the way around the bracket where it attaches to the boat. There was no excessive vibration when running the engine or never hit a thing... no leakage inside that I can find... I can't move the bracket by hand at all. BUT, the crack is still wet after 5 days, which tells me that there was leakage somewhere.Any idea what to do? I bought the boat without the motor running, so I don't know what the previous owner had experienced. It doesn't seem like the prop shaft is bent, the prop looks fine to the eye, i.e. no gashes, etc... them motor ran smooth... but then boat vibration is a matter of opinion, i guess, too. any help would be appreciated.Markus
