Recommended prop.
Dear Jim:Thank you for your letter.If the current two blade is not set correctly, you may see additional speed when you convert to the three blade. If the two blade is set correctly that speed increase will only happen when the vessel is confronted with additional strain on the vessel like maneuvering, stopping and accelerating, heaving winds or seas and possibly towing something. The three blade will also help to reduce noise and any vibrations which are a result of the two. The recommended three blade will depend on your current drive train combination, (for any one else reading this note with a Hunter 30) so with the 1GM 12, your recommended three blade is a 13” diameter with 8” of pitch. If you should have any other questions please do not hesitate in asking. Sincerely, Kevin L. Woody
