C
chet p
when i changed my engine last year i questioned you about the prop saver device you sell that goes between the two halves of the shaft coupling..I purchaced one and installed it.....well now a friend has informed me that i should have some sort of bonding between the two coupling halves to pervent galvanic action on the prop and shaft....????? should i put some sort of connection between the engine and the shaft as it now appears isolated due to the insulating properties of the shaft saver device...........oh hell another thing to work on, as if i don't have enough to do already thanks chet p
