Prop question, again
9
Catalina Catalina 30 Point Lookout, NY
I have decided to change out my Two Blade to a Three. I was advised by some on the forum to go with a RH 13/10 1" Shaft prop. When I contacted Cambell as was also suggested they recommended a RH 13 X 8 X 1. The difference is in the pitch. Is there a right answer? It is an 89 Cat 30 TRBS, Wing with the standard Universal M25XP. I need to get an order into the system ASAP or will miss out this season as I splash in the next week or so.
Nov 2, 2008
137
Beneteau 331 Chicago (DuSable)
I had a similar situation a month ago. I was a 14 year Catalina 30 owner before I went with a Beneteau. Always will have a special spot in my heart for Catalina. Anyway i went with a campell prop. Very impressed and tmorrow is the river trip to the harbor. I went and trust Norm on his recomendation which was a 15 x 8. Had some people online question th pitch but I will try what was recomended. Will know tomorrow if it was correct. It is an impressive shape of the blades.
464
Catalina 30 MKIII Varuna Boat Club
My '91 30' MKII, St'd rig, wing keel, M25x came from the factory with a 13x10.....if that's of help to you.
Good Luck and Happy Sailing
