I don't paint them
Dear Greg,Being in the propeller business, one of the single most challenges we face is keeping the biological off our props. People talk about STP oil treatment, Desitin, Copper… and painting the props. We find in our repair shops that the propellers that comes in with paint on them causes the average repair to cost apx. $100 to $200 more, as a result of the galvanic reaction or the oxygen starvation problem the paint or sealer may have caused. Of coarse our propellers are made of Nibral and your fixed may only be bronze, so there may be a slight difference in galvanic reactions. Our past experience has shown that if the paint is applied without following the etching process called out by the paint guys, it will not stay on the prop. The best material, paint, we have found is a product called Prop and Drive. NASTY stuff. Tribudilean (sp) aka Tin. Can be very harmful to water based animals and humans in applying and removal. Some prop shops will not accept propellers with the stuff on them. Causes cancer in mammals. To get biological elements off prop, try red or black 3M scratch pads they work great. Just try to not remove metal. I would suggest if you leave the vessel at dock for long periods of time, try smearing DESITIN, baby diaper rash ointment, all over the surface of prop. The zinc oxide stalls biological growth. It will sluff off however when the propeller is being used. Good luck. Sincerely, Kevin L. Woody
