Prop missing
WEP
Jun 7, 2004
3
- - Greenville, NC
I recently purchased a 28' Irwin. It has an Atomic 4 inboard engine but the prop is missing. What size prop does it take.
Ed A
Sep 27, 2008
333
Hunter 37c Tampa
not sure of the size but i think i have one
I think i may have one stuck out in the boat shed. when i get down there ill check it out for ya. took the engine out a few years ago.
Dec 2, 1999
15,184
Perfect Solution
Check this out. It is a perfect solution for an A4. http://www.sailcdi.com/ppmain.htm
Jun 24, 2004
6
Oday 27 Lake Sinclair
3 blade alternative
Your best solution for re-propping an Atomic four would be to go with the 3 blade Prop that Indigo Marine has. It outperforms anything that I have seen for the Atomic 4. Go to their web site , you will find the exact address if you search under the Atomic Four search engines. Good Luck
