flexofold results
OK, got the boat in the water and tried it out. It sails like a bat out of hell now - I figure I picked up close to a knot in boatspeed, but some of the credit has to go to the (somewhat overdue) bottom job. Performance under power is better, too, but I have to add that the original three-blade prop was oversized for the motor.Now for the bad news - serious vibration above 1800 or so RPM. It starts to smoothe out some above 2800 RPM, but it is a problem. Of course, I'll recheck the shaft alignment, but I have a bad feeling the shaft is whipping. This may be due to the shaft length - the prop hub is some 4 inches or so aft of the strut. More to come.In answer to your question, the vendor will need to know your shaft size, but the keyway and taper should be standard. One thing - make sure there is room for the folded blades not to hit the rudder.
