Prop in gear or neutral when sailing?
27
Hunter 34 Worton Creek Marina, MD
Up to now I've been sailing with the trans in neutral. Just read a post saying the transmission needs to be engaged. I gave a fixed blade prop. What is everyone else doing?
Mar 20, 2007
500
Catalina 355 Kilmarnock, VA
Lots of previous discussion on this - check the archives. Bottom line - depends on the manufacturer of your engine/transmission. Yanmar = neutral (required by warranty), others = variable, but never locked in reverse.
Mar 20, 2007
500
Thanks Stu - you are absolutely right, I had a brain freeze. Should have said never leave in FORWARD.
