Has anyone tried the Prop Guard that sells for about $85? If so, I was wondering if it had any effect to reduce "prop walk"?
Sailingdog:
It may not be called propwalk, but I believe that an off center outboard causes something quite similar to prop walk or maybe even worse.
All least my first Kells 22 had a significant problem. The outboard was mounted well to port on the transom. I think that the wash against the rudder doesn't help either. Backing wasn't even a consideration in that tub.
Mike
Judging from the responses, I guess no one knows.
Thanks anyway, Barry
