There hae been a zillion
treatments for keeping barnacles off the propeller. Zinc oxide baby ointment was really big a few yeras ago as was Teflon grease and just about anything else. None work. Water flow quickly remoes them and the barnacles climb on. Water flow does not bother them. Anti-fouling paint doesn't work either. Howeer, if you do not put zincs on your shaft and prop hub, barnacles will stay away because then the bronze leaks copper ions. Of course, in a little while you won't hae a shaft or prop.
