Prop info Hunter 31
Talk about timeing. I just recevied the latest issue of Practical Sailor, and someone asked the Advisor that very question. Here's the question and answer:Propeller AlternativesYou have done two excellent articles comparing the relative performance characteristics of various types of small boat propellers (Oct 1, 1993 and January 1, 1995). From those articles and the other reading that I have done, I have concluded that the best propeller to replace the existing folding one on my 35-foot sloop is a feathering propeller. The issue I am having trouble resolving is the benefit of a three-blade feathering propeller over a two- blade one. The boat is underpowered by today’s standards, therefore I want to maximize the engine performance. My question is whether, for a given horsepower and engine RPM, a three-blade feathering propeller will drive the boat at a higher speed than a two- blade propeller? In adverse conditions (wind, seas) will the three-blade propeller outperform the two-blade? -James D. Phyfe III, Hong Kong A three-bladed prop will produce stronger, smoother thrust than a two-bladed prop, which means it will be better at pushing the boat into strong headwinds and chop. Feathering props are a bit less efficient than fixed-blade props at driving the boat forward, mainly because they have less twist built in so that they present less drag when feathered. Even so, a feathering three-blade should be more efficient than a fixed two-blade, and a lot better in reverse. Boatspeed is another question with more components. If, for example, your boat’s maximum hull speed is 7 knots and you can reach that speed in flat water with your two-bladed prop, you’ll probably be able to reach it more easily with the three-bladed prop at the same RPM, and cruise at 6 knots at a lower RPM (depending on how your engine is geared). The three-bladed prop won’t have much of an effect on top speed in flat water, although it might muscle the boat ahead a bit faster at the cost of fuel and engine wear. Again, it will be a good deal better at getting you home in a headwind. You should check with an expert to make sure your engine is geared right for the prop in question. We have a good shop here in Connecticut called the Essex Machine Works. Number: 800/724-0528. You can ask for Bob Claps. Also, read Dave Gerr’s definitive Propeller Handbook, available from International Marine Publishers at 800/262-4729. --------------------------That was interesting. Today, I just happened to drive by a prop shop and went in to talk with the folks. I learned a three blade prop will significantly increase the thrust at low speed, and provide more power/speed using less fuel. I also learned there are different props for sailboats and motorboats. The ones for sailboats have a teardrop shape to the blades. A motorboat prop will provide even greater performance than a sailing prop, but with greater drag. However, my boat is so underpowered with the 2GM engine that I'm seriously considering the motorboat prop. I know this is tanamount to a sailor's sin, but right now the lack of thrust is dangerous.Maybe a 3-blade sailing prop will be good enough, but I don't have a lot of money to play with and can't keep trying props till I find one that works right.Scott FraserHarborage Marina; Slip A-211110 3rd St. So.St. Petersburg, FL 33701-5525
