Prop for 1968 Morgan
Jim Gordon
I currently have a 12 x 8 two bladed prop on my 1968 Morgan 30. Top speed under power is about 4.5 - 5 kts. The boat is powered by an Atomic 4. Running at 1200 rpms which seems to be optimum . I would like to get it to go a bit faster. I am wondering what props people are using on their boats. > Thanks, > Jim Gordon > S/V Allegory II > Norfolk, VA
Ross
Jun 15, 2004
14,693
Jim, I sail an Islander 30
When I re-powered I went with a 10hp diesel with a 3:1 reduction gear and a 13x15 three blade. I get about 6 kts. at about 2600 rpm engine. the thrust is very large if I try to run harder I bury the stern and push a large bow wave. My prop would be better if it were 13x13 three blade but for 75 bucks used in the marina shop beggars can't be choosers
Aug 3, 2005
181
Morgan 33 O/I Green Cove Springs FL
Yer RPM is a little low
Ahoy Jim, You need to get a little more rpm from the Atomic Bomb the max horse power is up around 2600 rpm. Indigo Electronics has a prop designed for the A4 that really really works. I bought one about 6 years ago for my old boat and I was truly amazed at the improvement. I can't say enought about the thing.
