Props
Hi Cookie -As you said, there has been much discussion on this topic in the past. It really comes down to what you value most in a prop - cost, drag, thrust (forward and reverse), flexibility, etc.Folding props typically provide the least drag under sail, but come up short when it comes to thrust, moreso in reverse. Fixed blade props can be fit to provide the best thrust under power in forward, but allow the most drag under sail. Feathering props are a good compromise that provide minimal drag and reasonable thrust (reverse is much better than folding or fixed). Of the feathering props, Max and Autoprop are the most popular - Max has flatter blades and provides a bit less drag than the Autoprop, but the Autoprop is self pitching and provides the best motor-sailing abilities. This is a synopsis based on my reading and ovservations - hope this helps!Best,Trevor
