One Additional Point
David,You're going to need to use a modified epoxy paint on the prop & shaft. Ablatives are designed to "wash away" over time on a normal hull, but on a shaft & especially the prop, ablatives won't last long enough.John's right to stay away from the cutlass bearing...it's going to need water to lubricate & cool itself, but you should also not paint the zincs or underneath where the zincs attach to the shaft. Bottom paint could electrically isolate the zincs and render them useless.Good luck!Allen Schweitzers/v FalstaffC-30 Hull# 632
