ProMariner Protech-4 Series On board Battery Charger
Sep 26, 2008
742
Hunter 340 0 Wickford, RI
I would like some input from others here regarding my 2000 340 (original 2000) ProMariner Protech-4 Series Battery Charger.
I‘ve never had any issues with it in all these years and still don’t.
I’m on a mooring all season and only use the charger while the boat is on the hard for the winter. I know, Not the best battery maintenance routine but its what I can do.
What I have is (2 - 6 volt golf cart batteries Flooded Lead Acid, wired in series - House Bank) (1 - 12 volt Reserve Flooded Lead Acid)
Today I noticed the panel that covers the charger settings was loose. So I took it off and looked at the settings the charger is set to. Not an easy feat by any stretch.
1. Set for Lead Acid Batteries
2. Set for 1 Hour Absorption Rate
I am looking for advice as to whether the Absorption settings are right. The batteries charge just fine, but looking at the page from the manual I have there are other setting’s available to me.
Please excuse the quality of the photos, as this is not the most conveniently accessible area to get a camera into. Let alone focus and click the button. I did mark the settings on the photos to help and included the page from the manual I have.
Do others use different rates of absorption hours than mine is set at and why.
Thank you for the help.
  • Helpful
742
Stu,
All very valid points. I’ll start looking at new ones now. Thank you for the links. And a more accessible area to mount it in.
sc, glad to be able to try to help. You didn't say your charger was a "Flyback" model but I figured from the year it could have been, so gave you the info; most appreciative that you read it and found it helpful - you'd be surprised at how many don't. :banghead::banghead::banghead:
I also suggest you keep it disconnected until you get a replacement; because fire...
Oddly enough, the most preferred replacement is now also named ProMariner, but by a completely different company. Sterling makes an identical model. Maine Sail has an excellent writeup about them:
Good luck, all the best.
  • Helpful
742
No its not a Flyback model. But I have seen them before, years ago, on others boats. I‘ll get into MaineSail article later this weekend. Thanks for the help and guidance Stu.
:plus:
Stu knows his stuff.:clap:
Likes: FastOlson
Jun 16, 2004
26
Beneteau Oceanis 461 Kiawah Island, SC
I recommend a battery maintainer when laid up. It's a small trickle charger, that cannot do what Stu said. Used for antique cars, mowers and boats.
The 1 hour float time is weird to me. Mine is automatic, 3 states. Bulk, float, absorption.
