I hope it's ok to put this here. I see there is a classified section, but this boat isn't actually for sale.Since I see lots of talk about project boats, I’m wondering if anyone might be interested in a project Islander 30 from 1974. It was damaged in hurricane Katrina, has a hole in the hull of unknown size and location, is in shallow water from which it has to be lifted out. It has had a good bit of water in it. Just how much I can’t say. When I got back to it (a month after the hurricane), it was tilted towards the bow, and the water went from just below the engine to just over the point of the bow. I put a Rule pump into it and pumped for an hour without changing the water level inside which was same as lake outside. Since then, the lake level has dropped enough that most of the water is gone, but there is a good bit of muck inside. There are several dock storage boxes in the water near where the boat came to rest, and one might go with the boat and have a spinnaker in it. Some large crane operations were charging $150 a foot to pick up boats. But a friend suggested that he had rented a cherry picker crane to handle some beams up in the Chicago area and figured an energetic enough person might use one to pick up the boat for a lot less. The boat weighs about 8600 lb, and ads show cherry pickers handling considerably more that that. The mast and all rigging has been taken off, so wouldn’t get in the way of do-it-yourself salvage. The mast is good, but the spreaders have been bent. The Harken roller furling has been taken off also, and the top section somewhat cut into; don’t know if this damage is just superficial. It has a Palmer engine that was running well; compression on 3 cylinders was about 120, on 4th was about 90. Don’t know present condition. Since I’m 76 and have enough other projects, I’m not interested in this one. Anyone interested?
