Profurl R250
17
Hunter 22 Perdido Bay , Florida
I purchased a Profurl R250 for my H22. I plan on mounting the drum low to the deck, without a turnbuckle using a toggle. The rig will be tensioned via a backstay adjuster. My question is.....pin to pin length of the stock headstay and wire diameter. Thanks !
Alan
Jun 2, 2004
4,174
Hunter 35.5 LI, NY
Headstay length
It depends on how much mast rake you want. If you are fitting a non- adjustable headstay then the mast rake will be set by that length. Typically mast rake is set at 1% of mast height. Very small changes in headstay length will have a profound affect on the rake. This is a bad idea.
