To Check
Don't know anything about your unit but I do have Selden in mast on my Hunter 36 so maybe some things I can suggest to do to help,is the main haylard tight and are you making sure you are furling the sail in very tight so no bunching of the sail is happening.
Start by pulling the sale all the way out and adjust the main halyard as tight as possible with the winch but be careful to not over do it and check the turning barrels where the sail attachs for need of lube and if everything looks OK than furl it back in but keep tension on the out haul so that the sail wraps nice tight and smooth with out any bunching up of the sail.
Also check the rig won't hurt making sure the mast doesn't have too much bend in it and everything else is OK.
If none of that helps I would call the Profurl for help and maybe they can suggest things to do and maybe some one who knows or installs their equipment.
Nick
