Searched the archives for problems with throttle cables and found a good selection of advice. My throttle was extremely stiff to move up or down. In particular, mine was sticking and once throttled up, would not throttle back down completely, leaving the engine at higher RPM as we headed toward the slip. It happened at the end of last season, so I had a chance to look through the archives over the winter and prepare to replace the cable and follow the other advice from the archives.I detached the cable at the transmission box at the engine yesterday and....what's this? The cable was quite limber and happy to move freely. It turns out the small arm that connects into the transmission at the engine was as stiff as an old man's back. It all but refused to move. A couple of shots of CorrosionX (or probably any good lubicant) got the arm moving nicely (wish the same could be said for my back). Reconnected the cable, and all is good.Just thought I'd throw it out there in case anyone has come across a similar problem. Never thought of it as part of regular maintenance but curious if others have run into it too. For the sake of a drop of oil, it saved me from a far bigger chore.Paul
