Problems Maintaining Straight Course
10
Macgregor 26 feet Marina del Rey, CA
We Bought Our 2012 Macgregor 26m At The Factory Last Oct.
Done As Much Sailing As Time Permits. Only Found One Thing Annoying About This Boat. And I Researched It Thoriughly For Two Years Before Owning It.
That Boat Will Not Keep A Steady Course. With Calm Seas And Good Wind We Set The Sails And Head For A Decided Point Of Distant Land.
Yet It Is Necessary To Constantly Compensate At The Wheel.
Ive Owned Other Centerboard Boats.
The Boats Obeyed The Rudders.
On A Mac 26m, What Can Be Causing The Boat To Not Be Going Exactly Where We Want To Go.
Appreciate any advice. This boat should not be wandering. It's Rogers best ever.
Sumner
Jan 31, 2009
5,254
You might also consider asking here....
http://www.macgregor26x.com/forum/viewforum.php?f=16&sid=3f70476593e3deebae82cb36b3c5f9c9
Lots of M owners over there. I think I've seen that come up before over there, but I didn't pay much attention. I know I've seen them suggest different combinations on the rudders and such.
Like Bill said probably more of a sail trim deal. Also is it worst on one point of sail vs. another?
Sum
[FONT=Arial, sans-serif]Our Endeavour 37 [/FONT] [FONT=Arial, sans-serif]
Our MacGregor S Pages
[/FONT]
[FONT=Arial, sans-serif]Mac-Venture Links[/FONT]
Feb 26, 2012
10
Thanks For The Suggestion. Sail Trim Is Ok. Occurs On Either Side Of The Boat. Did Test Different Sail Trim Combinations Plus Reducing Sail Areas.
Could Be Rudder Problems.
Oceanview2
Jun 5, 2004
997
Macgregor 26D Boise
Sorry about that first post- couldn't resist. The last M that I inspected was brand new. I felt that the play in the rudders was unacceptable, and it only goes downhill from there. The steering linkage could be improved: any part where a bolt passes through a piece of tubing could be better re-inforced. Oversizing the holes will remove play, but you only want to do that once.
Dec 17, 2008
11
MacGregor 26M Québec City
The M sells for 22,000$ new from the factory. What does one expect for a 26 foot sailboat that sleeps 6 can take force 5 conditions sail at 10 9 knots and motor at 18 miles per hour for 22 g's?
Feb 26, 2012
10
THANX FOR BOTH YOUR INPUTS.
AND YES, what can one expect from a boat that is everything but amphibious and capable of flight.
I WILL INSPECT RUDDERS. PLAY. MECHANICS STEERING SYSTEM BELOW DECKS.
APART FROM THAT, A GREAT BOAT.
VERY SAFE.
May 4, 2005
4,062
problems on ALL points of sail? or just one? (broad reach to close hauled)
ie., downwind, I can't let go in any kind of sea, but I can balance the sails and let go in light to medium conditions and it will track pretty good... *if I don't move about and upset the balance.
-you might find an auto pilot in your future... that should solve it. at a price...
GL!
Jun 5, 2004
997
Macgregor 26D Boise
Please remember I myself have a Macgregor in my side yard. I only state what I see when I inspect a craft, whether auto aircraft or boat. Don't get defnsive, just upgrade the weak parts.
Feb 26, 2012
10
Rudder Alignment Adj. Advice.
Must The Twin Rudders Be Close To Perfectly Parallel To Maintain Good Directional Control ? On The Same Page In Respect To Their Alignment ?
And If This Is Critical, What Is The Proper Way To Set Their Alignment As Close As Possible To Correct ?
Feb 26, 2012
10
Thanks For This Advice. We Have A Huge Mcmasters Carr Just Down The Street. And Tie Rods May Be A Viable Strong Fix.
Come In Different Sizes And Qualities. Even With Zirc Fittings. And Stainless Also. Very Strong. Bravo Zulu.
Feb 26, 2012
10
Re: Tie Rods
IT WOULD BE LOGICAL THAT MISALIGNED TWIN RUDDERS WOULD BE HAVING A TUG OF WAR OVER WHICH DIRECTION TO GO. MAKES SENSE.
Feb 26, 2012
10
Checked This Out During The Occurance Of Our Problem. Little Effect. Continue Looking At It As A Contributing Factor
Thanks Bill
May 4, 2005
4,062
on my hobie, I would align them just like a car.
take 2 rulers and measure the distance at the front of the blades, and the back of the blades. you'll have 'toe out' toe in, or zero toe.
the question is how much slop exists.. if anything I'd go for some toe in. vs toe out. (shorter at the front the the back).
-my thinking is under load, they will tend to toe out, so if you start with a little toe in, you might end up at zero under load....
you'll need a extra pair of hands, and measure at the same place vertically on the blades.
