problems in Alaska
Jun 12, 2010
17
Hi
I am the new owner of V2417 I purchased her last month in Juneau and in the past 9 days brought her to her new home in Sitka. A little background on me I am 70 and have not sailed since my teens racing snipe class. My wife and 9 kids convinced me that now would be a good time to buy the sailboat I have always wanted and quit riding my motorcycle because of my age. So I bought the boat (but still have the motorcycle). So off I go to Juneau and prepare for my trip, changed oil, filters flushed fuel tank and lines and changed fuel filters and away I go (probably too excited to better prepare, oh well). In a heavy rain nearing Chatham strait sudden silence and it is now nightfall, a quick check rveals that my battery is dead, the wind dies and I am now adrift in a heavily travelled area with BIG cruise ships speeding nearby. While working on the problem a ship passes by while I am in the cabin and it's wake hits me broadside in surprise resulting in me doing a faceplant wood wins and I wind up with tear in the side of my nose a swollen eye that is bleeding a cracked rib and a wretched knee. I spend the next few hours stopping the bleeding and shining my flashlight on the radar reflector and sail. I have no running lights no radio, no GPS, and am about out of TP before the bleeding is reduced. The wind returns with a vengence 25 to 30 in heavy rain and 3 to4 ft seas but I manage to get the jib up and a double reefed main, I do this with a harness attached to the Stearns immerssion suit and crawling any time I am out of the cabin. Before dawn the wind dies and I am back to drifting. I am able to flag down a fishing boat and they tow me 12 miles to Tanakee where I am met by the EMT's no doctor or clinic available so we just apply compressess and clean the blood, I decline the suggestion to call the Coast Guard for a helo medevac. I rest and the the next day I buy a second battery and charge both batteries will shorepower at the dock. I discover that the engine oil is overfilled so I drain and change it again. cannot resolve charging problem, the starter/ALT has been replaced with a German made unit that is a starter/GEN. So on my way again good wind, no wind, rain always, I get into Angoon wet tired hungry and spend the night. In the morning I find that the oil is overfilled again so another change. Off again on my trip and the is used about 3 hrs and sail the rest, total trip time 9 days. Doctor said the eye was bleeding from a cut on the inside of the eyelid and would heal fine the nose had lost some meat so it is too late for sutures and I might just as well get used to my new look, the knee will heal without any treatment. Where is my oil increase coming from, I'm sure it's diesel? Anybody have a wiring diagram for the genarator and voltage regulator? I am looking forward to a lot more sailing but without the problems, my wife will come with me if I guarentee a hot shower and B&B once a week. We plan to cruise SE Alaska next summer but for now it's varnish and repair.
Remember we must all grow old but I refuse to grow up!
Frank Vega #2417
May 30, 2006
1,075
What a great story.
You just lived all of sailing in one trip!
Also, you have found the right place for your information as it is all here.
Welcome.
Roy
Nov 21, 2002
34
I can't offer you any advice but I do have photos of your Vega at Tanakee. I was
a passenger on the Northern Song, the blue 80 foot motor yacht that anchored off
the Tanakee Dock for 3 hrs then crossed over to Crab Bay (I believe its called
that) for the night. I was impressed to see you up there. I have one down here
in L.A. Better luck in the future.
Brett
________________________________
To: AlbinVega@yahoogroups.com
Sent: Thu, September 9, 2010 8:40:38 PM
Subject: [AlbinVega] problems in Alaska
Hi
Frank Vega #2417
Nov 8, 2001
1,818
Hi Frank
Sounds like there is a leak between teh seal on the diesel injector pump and teh engine itself. Not a vastly difficult job but the pump needs to be taken off and I sent mine to a diesel repair shop where they cleaned, calibraeted and changed the seal.
Usual charging on your Vega is to have two sources:
1. Dynastart. This is a combined starter and dynamo (about 10 amps) and is uasually wired to charge the engine battery seperately
2. Alternator. This is a standard 35a alternator usually wired to charge teh domestic battery system seperately.
Hope this helps and good luck, must change soon!
Steve B
Oct 31, 2019
34
Yes, the oil increase is coming from diesel, a loose injector line, or fuel
pump leaking by into the crank case. Smell the dip stick, and I'm sure it
stinks like diesel. It needs to be repaired asap, and the oil and filter
need changing before the engines runs again
Oct 30, 2019
119
You didn't happen to notice a vulture on your stern rail did you? (This in
response to a post from a Brother Owner who got scared out of toilet paper
by one!)....................Sounds like you are a tough ol' bird yourself
with a tough lil' boat. Keep us posted..............Craig (Vega 936)
Dec 24, 2009
60
Hi Frank, thanks for your story and thanks for sharing it, BUT.... its a also a story about how not to do things, and its not good seamanship what you did. It takes some time to get to know a new boat.
I bought a Vega 3 month ago, and if I had been in your situation, there´s a good possibilty that I would have done the same as you. I also take chances. To many some times and I also sail alone where you pay double for your mistakes. Your story reminds me of that, so thank you for that. Its always good with a reminder.
Anyways, great reading. I hope you recover well from those injuries, and while you repair that engine, take the motorbike for a swing.
BTW, I´ve made a few guitars with Sitka spruce, one of them I play on a daily basis and its not for sale, so clap a tree from me and say hello from Spain
Anders
1118 "Yggdrasil"
Oct 31, 2019
163
Welcome to the fold Frank.
Good luck with the engine/charging system overhaul; I do have a wiring diagram for our Vega, but it's a one-off to suit the way we've got it wired, so would probably only confuse things if I sent that, but I do have a pdf copy of the Volvo MD6A - I assume it's one of these you've got fitted? - which I will attach - it won't attach, so I'll try sending it to your email address - it probably won't be exactly as yours, but it will point you in the right direction with the wiring.
Bob Carlisle
Spring Fever 1776 - back sweating it out in the eastern Mediterranean.
PS - ALWAYS keep the motorcycles.
Sep 2, 2002
1
I'm also a sailor in Sitka. I lusted after a Vega for many years but never
found one I liked so I ended up buying a Bristol 35 to restore. I'd enjoy
swapping SE Alaska stories and providing any help I can to you. Feel free to
contact me offlist at nitejazz@.... My boat is located in Thomsen
Harbor slip C14. I'm freqently there on Weekends and after work.
-j
