Problem with Raymarine ST60 Wind ?
278
Hunter Passage 450 Lake Lanier, GA
My Hunter 450 has Raymarine ST60 wind, speed, and depth instruments all mounted side by side above the companionway. On my last visit to the boat I noticed that the wind instrument was no longer working. The back light was working and I took out the unit and could not find any loose wires, also the mast mounted sensor seemed to be functioning normally. The time before at the boat just 4 days earlier it was working fine. I am hoping not to have to go up the mast.:cry:
Apr 18, 2007
53
Jeanneau Sun Oddysey 40.3 Chicago, IL, USA
Check the connection at the foot of the mast. That may be loose or corroded. If that's good then you're probably taking a trip up ;-)
May 25, 2004
444
Catalina 400 mkII Harbor
raymarines web site has a guide for you to check the transducer wire voltage output. sorry i dont have the link but its easy to search. you will know then if your transducer is functioning properly
mike
Oct 24, 2011
278
mike
Mike,
Thanks for the info...hopefully it will save me a trip up the mast.
Jun 4, 2004
834
Hunter 340 Forked River, NJ
I also have a problem with my 11 year old ST-60. You can remove the wires from the back of the display unit and clean the contacts and that might help. My unit displays wind speed but not direction. I called Raymarine and the tech told me that the masthead units rarely fail and that I should replace the display unit. Maybe next year I can afford the $500 price tag. For now it's yarn on the shrouds.
Nov 6, 2006
10,149
As Marty says, I'd first suspect the first connector after the mast run. ... the one that has to be disconnected when the mast is removed. I am thinking TackTic to replace mine. My wire was somehow ( multitool operator, me) cut during the compression post repair and I don't want that wire in there anyway..
Oct 24, 2011
278
Looks like the display unit will be going in for service..I registered and checked on the Raymarine forums and I do have the proper voltages going into the unit.:cry:
In the mean time I get to hone my sailing skills using my windex and telltales.
Dec 19, 2006
5,832
Hunter 36 Punta Gorda
E-Bay
Lots of Raymarine parts can be found on E-bay and some times even save $$$$.
Nick
Jun 28, 2005
440
Hunter H33 2004 Mumford Cove,CT & Block Island
$185 Repair
I had the same symptom, Raymarine repairs/exchanges mast head unit for flat $185 fee. I can't believe your tech said masthead units rarely fail!
Repair center is in NH USA. My understanding is that the heading sensor is what commonly fails.
