Our boat came equipped with an Adler-Barbour/Waeco Coolmatic CU-85. I do realize that not having enough insulation is a common problem with marine refrigerators, particularly icebox conversions like this one, causing them to run more often. But in this case, it seems like when it does run, it consumes what I believe to be an abnormally high amount of power. For a while when first turned on, it draws over 8 amps. Eventually, after running for a few hours, it settles down to about 6.5 amps. But according to the unit's data plate, it says that it should draw 45 watts, which should be in the neighborhood of 3.5 - 4 amps, right?
I also noticed that after it's been running continuously for a while, the compressor gets quite hot... hot enough so that I cannot keep my hand on it for more than about 5 seconds. Is that normal?
It does cool well though.
--Michael
--Michael
